May 20, 2020, 15:39 |
Problem with reading a pdf transport file
Akram
Rep Power: 9 |
Hi all
I have a problem with reading a pdf transport file When I run the case file on ansys 19.1, and then I try to read pdf transport file (case.pdf), an error message appears saying that Version of the file (pdf file) : "fluent18.0" and fluent stops. Can anyone help with that? Thanks |
May 20, 2020, 15:50 |
Pdf
PDFs have version compatibility but only if there are no structural changes. From 18 to 19, there might have been some changes to the format. Better to generate new PDF in 19.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 20, 2020, 15:58 |
Akram
Rep Power: 9 |
The pdf table was created in a 19.3 version, but when I come back to log file, I find the the following :Version of the file: "fluent18.0"
I don't know from where 18.0 came |
May 21, 2020, 06:49 |
Pdf
The generation of the PDF does not write it. If there was an existing PDF file of same name, then, you will have to overwrite it. You can open PDF file in any text editor, such as, vi, gedit, or textpad and look for the details inside it.
April 28, 2021, 02:40 |
Non-premixed combustion-Fluent (Cluster)
Rep Power: 5 |
Hi all,
I am using the Non-premixed combustion model for my case in the Transient step. Therefore, I have calculated a .pdf file for species. However, when I try to run it in the cluster, cluster won't able to read it. In fact, when I try to open this .pdf file on my local machine, it doesn't open. Can someone please help me with this issue? Kind Regards |
December 13, 2022, 18:03 |
#6 | |
TX
December 15, 2022, 08:20 |
#7 | |
gugtenterf
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
