May 11, 2020, 16:18 |
Adding a contours using TUI
Rep Power: 6 |
Hi every one,
I want to create a temperature contour on a named selection using TUI. My goal is not to use display command and then save the picture but rather I want to add a new contour same like one would do using fluent GUI. Does anyone know if this is posible? Thanks |
May 12, 2020, 02:18 |
Alexander
Rep Power: 34 |
what do you mean under ADD?
select additional surface to be displayed? as far as I know, for TUI you should create object first. which will be displayed starts with Code:
display objects create contour NAME ..... Code:
display objects display NAME
best regards ****************************** press LIKE if this message was helpful |
May 14, 2020, 15:47 |
#3 | |
Rep Power: 6 |
Thanks Alexander. I tried jus as you suggested to create and then display. Here is my code: /display/objects/create/ contour Temp34 color-map/format "%0.1f" q field temperature range-option auto-range-off minimum 25 maximum 34 q surface-list hs () () q however when I try to display this, the ranges dont work and some random ranges are created(like -240 instead of 25 and 34). Do you see any mistake in my code? When I try to edit the object in TUI I see that the min and max are still save, but when I display then fluent uses some wierd numbers as min and max. |
May 21, 2020, 09:25 |
Rep Power: 6 |
I found out. All the temperatures within TUI must be entered in Kelvin. This was the problem.
Incorporating pyrolysis Model in chtMultiRegionFoam | Archana V | OpenFOAM Programming & Development | 31 | April 2, 2022 02:11 |
multiRegionHeater error | ordinary | OpenFOAM Running, Solving & CFD | 2 | June 9, 2020 17:43 |
conjugateHeatFoam + interFoam | farhagim | OpenFOAM Programming & Development | 15 | July 19, 2016 07:55 |
chtMultiRegionSimpleFoam | samiam1000 | OpenFOAM Running, Solving & CFD | 39 | March 31, 2016 08:43 |
[General] Adding labels to line contours | nikhil5490 | ParaView | 0 | July 5, 2014 10:03 |
