May 25, 2020, 01:56 |
Bias factor vs expansion factor
Ahmed
Rep Power: 6 |
I am validating an old paper which says ( expansion factor of 1.27) but I didn't find sth called expansion factor in ansys meshing and all I can find is bias factor instead
1) what is definition of each ? 2) how to convert from one another? |
May 25, 2020, 12:17 |
Expansion Factor
Expansion factor is not a user-specified parameter rather determined using the generated mesh. It is important, but usually used in CFX simulations and CFX calculates it and reports it, while Fluent does not. It signifies the variation in expansion of a cell as compared to its adjacent cell. So, it is not a cell property but a mesh property and changes from location to location.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 26, 2020, 02:44 |
Ahmed
Rep Power: 6 |
So there is no way to generate the same exact mesh of this CFX in fluent ? In other words can't I turn this expansion factor into bias factor?
May 26, 2020, 11:26 |
CFX vs Fluent Mesh
Mesh is not handled same way in CFX and Fluent. So, you don't even need to worry about the expansion factor. As long as skewness and orthogonal quality are good, the mesh is fine. Maintain growth rate lesser than 1.2.
Bias factor is a ratio between sizes of largest and smallest cell, not the adjacent cells while expansion factor is related to adjacent cells' volumes.
[ANSYS Meshing] edge sizing control--Calculate cell-to-cell expansion rate from bias factor | la7low | ANSYS Meshing & Geometry | 6 | December 19, 2021 06:49 |
Long output in terminal. | ssa_cfd | OpenFOAM Running, Solving & CFD | 1 | March 18, 2019 05:25 |
[blockMesh] Create internal faces as patch in blockMesh | m.delta68 | OpenFOAM Meshing & Mesh Conversion | 14 | July 12, 2018 14:43 |
expansion factor in mesh quality | wjy-c | CFX | 8 | August 25, 2013 00:04 |
Maximum mesh expansion factor | Daniel | CFX | 2 | September 27, 2007 01:47 |
