spcify heat sink and temperature on a wall
Old   May 26, 2020, 08:08
Default spcify heat sink and temperature on a wall
nima103 is on a distinguished road
Hi
I am trying to simulate conduction as seen in the attachment. I have a wall with as a heat source and another wall as a heat sink. However I want to define also a constant temperature on the heat sink. So the question is as follows:
- If I choose temperature boundary condition on a wall, does it mean the I allow a heat flux on this wall? Or do I need to specify for the solver that this wall is acually a heat sink?
thanks
nima103 is offline   Reply With Quote
Old   May 26, 2020, 08:24
Default Fluid
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
What's in-between the boundaries, a solid or static fluid or flowing fluid?
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 26, 2020, 08:36
the whole body is a solid.
Old   May 26, 2020, 09:03
Default Conduction
vinerm's Avatar
Vinerm
If whole of it is solid then you don't need to use a tool. The temperature field will just be straight lines. And if you want to use tool, just apply heat on one side and temperature on the other.
Regards,
Vinerm
Old   May 26, 2020, 10:12
Thanks for your reply Vinerem. The geometry which I want to simulate is much complexes, but I use the image in the attachment to discuss the boundary conditions.
I am doubtful if your suggestion would yield accurate results. Is it accurate to define a closed system and a heat source with no heat sink. ? I used some other software(Optistruct) to implement what you suggested and it never converges unless I define a heat sink.
Old   May 26, 2020, 10:42
Default Heat Source
vinerm's Avatar
Vinerm
Are you applying a heat source or a boundary condition (theoretically, both are same)? If you are apply heat source, then you will have to apply boundary conditions on both sides, top as well as bottom. If you are applying boundary conditions using heat flux and you apply only heat flux on both ends, then the solution is no unique. Assuming, you are apply heat source, it is the job of the thermal conservation equation to maintain the flow of the heat. But you will have to apply boundary conditions on top as well as bottom. If any one of those are missing, then the solution won't be unique. I don't know anything about optistruct but Fluent will assume the boundary to be adiabatic if no condition is applied.
Regards,
Vinerm
Old   May 26, 2020, 12:02
Ok I guess the use of heat source became problematic here. So lets say I only use a positive heat flux on the upper side and a temperature on the lower side. My doubt is without the user defining a wall for the heat to exit from or a wall with negative heat flux, could I achieve accurate results or not.
I think if I define a positive heat flux on one wall, the I must define a negative heat flux on another wall to allow the heat exit from and keep energy balance and finally a temperature.
Old   May 26, 2020, 12:19
Default Temperature BC
vinerm's Avatar
Vinerm
The field variable for which the conservation of thermal energy is solved is T in case of constant properties. So, the specification of heat flux as a boundary condition essentially implies specifying gradient of temperature. And specifying T directly is used as it is. The flow of thermal energy is always from high to low thermal gradient. When heat flux is specified at one boundary, as per its direction, the heat flow either goes in or comes out. Due to this, a thermal gradient gets setup in the domain. When it encounters the temperature on the other boundary, the heat flow starts automatically depending upon whether the temperature on the other end is higher or lower than the temperature inside. So, don't worry. The conservation will be maintained properly with heat flux on one side and temperature on the other side.
Regards,
Vinerm
Continuity Equation for multicomponent simulation lordluan CFX 15 May 19, 2020 18:36
Conjugate heat transfer problems - Temperature Divergence KevinZ09 FLUENT 6 March 6, 2018 04:32
Natural convection on a PCB's heat sink (with CFX) elcino CFX 10 July 3, 2014 12:03
Help modeling heat sink aimee FLUENT 1 June 3, 2011 14:17
Simulation on Heat Sink Ken Adams FLUENT 4 June 26, 2007 16:03
