combustion does not work in my valveless pulsejet
Old   May 22, 2020, 07:55
Default combustion does not work in my valveless pulsejet
Barcelona
jabuor is on a distinguished road
Hi everyone,
I am working in my valveless pulsejet simulation and I can't get the expected results: It seems that combustions does not occur, thus there are not pulses...
I will explain what I have been doing for my set up, so if someone has any clue what the mistake might be, please comment below.
I have done a 2D problem.
Solver: Pressure-Based, transient, velocity relative, 2D Space Planar.
Models: Energy, k-e realizable, Radiation P1, Species Non-Premixed combustion (c3h8: propane)
BC: 2 fuel inlet: inlet mass-flow 0.1kg/s each;
inlet: pressure inlet 0 pascal Gauge Total Pressure;
outlet: pressure outlet 0 pascal Gauge Total Pressure;
wall: stationary and with 20W/m^2*K of heat transfer
coefficient (convection)
Methods: Coupled
Controls: I left the flow courant number predefined (200) and I lowered 0.2 every under-relaxation factor except the mean mixture fraction and variance.
Initialization: Standard, compute from all-zones in order to establish a mean mixture fraction of 1, temperature of 1600K and a 5m/s x-velocity. It was thought to start a simulation from a previous combustion.
Calculation: time step size: 0.0001s, Max iteration/Time Step: 20
I think the mesh is not a problem. As it is a big surface I will update 3 differents pics so you can give your opinion:
https://ibb.co/9G06PpD
https://ibb.co/Nj18dv8
https://ibb.co/F3TsgTW
I am also sharing the animations I have obtained of temperature and velocity so you can see how the propane is mixing properly but (VIDEOS UPDATED OF LAST SIMULATION)
https://drive.google.com/drive/folde...9h?usp=sharing
Pease, if you could help me it will mean so much as it is part of an important personal project Thanks in advance to everyone taking their time
jabuor is offline   Reply With Quote
Old   May 22, 2020, 14:50
Default update
Barcelona
I am simulating again but with the only change on the combustion parameters. Now I have chosen species transport and selected the Finite-Rate/Edddy-Dissipation on Turbulance-Chemestry Interaction.
The inicialization is the same but now I have patched most of the combustion chamber in order to decrease the pressure (-5000 Pa) and create compression. I attach the pictures of the patching.
https://ibb.co/F0NT0kC
https://ibb.co/C0WkgH0
Old   May 26, 2020, 09:25
Default Density
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
How are you modeling the density of the mixture?
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 26, 2020, 09:36
Barcelona
In the species transportation method I picked the propane-air mixture but I did not model any density, probably predefine. But as I read in different pulsejet posts it is normally used non-premixed combustion models and in those I think you can't model the density of the mixture. I really don't know what I am doing wrong.
Old   May 26, 2020, 09:39
Default Density
vinerm's Avatar
Vinerm
Until and unless you use real gas models, user has control over density method to be used. You need to use ideal-gas for pulse jet.
Regards,
Vinerm
Old   May 26, 2020, 11:18
Barcelona
For the non-premixed combustion the density was selected from the pdf created. So I believe I have to change pdf to real-gas-soave-redlich-kwong. I will try again Thank you
Old   May 26, 2020, 11:19
Default Density
vinerm's Avatar
Vinerm
If density is also coming from pdf table, then let it be as it is. Real gas is not easy to converge.
Regards,
Vinerm
Old   May 26, 2020, 11:36
Barcelona
okey... So I believe that was not the problem. What should I do?
UPDATE: the last simulation I obtained combustion and pulsation but in the inlet area and the gases were not eject from the outlet. I used hybrid initialization and PISO scheme. Also I diminish the initial temperature of the whole pulsejet to 1000K and I set 0.01kg/s for the inflow mass of fuel.
You can see the animations of temperature and velocity in the videos of the link: https://drive.google.com/drive/folde...4ToB7br-_4Re9h
ansys, combustion, fluent, pulsejet, valveless
Non premixed combustion - combustion chamber pressure Gadders FLUENT 2 January 14, 2020 14:28
Valveless Pulsejet andreia_melo FLUENT 2 August 8, 2018 10:51
A role of combustion modeling in flow solver? Yoon Main CFD Forum 0 November 26, 2006 12:00
Multiresolution + Turbulence + Combustion Raul Main CFD Forum 0 March 18, 2005 07:53
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
