June 2, 2020, 00:23 |
Slip velocity for multiphase flow?
reza
Rep Power: 6 |
Hi everybody
In a pipe, with FLUENT, I want to simulate liquid-solid as the Eulerian-Eulerian method, and for boundary condition, I selected velocity inlet, and slip velocity is very important for me. now my question: the inlet velocity for each phase should be the same? if inlet velocity is the same, slip velocity can be calculated? or for calculation of slip velocity, inlet velocity for phases should be different? thanks |
June 2, 2020, 09:08 |
Inlet Velocity
Slip velocity is affected by velocities at the inlet, however, it is also affected by many other parameters. Therefore, different or same velocity at the inlet for two phases is not a requirement for slip to exist. At the inlet, conditions should be set as per the available data.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
kindly help me .. i have and error at line number 147.. | m zubair | Fluent UDF and Scheme Programming | 0 | February 10, 2019 11:25 |
UDF comilation error. urgent help please | m zubair | Fluent UDF and Scheme Programming | 4 | February 10, 2019 11:19 |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 08:35 |
3D Velocity profile for turbulent flow | Kirill | Fluent UDF and Scheme Programming | 3 | July 17, 2014 08:42 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
