June 15, 2020, 08:47 |
temperature as output parameter
Lukas
Rep Power: 5 |
Hey!
For my current project I want to analyse the temperature at special points for different input heat power values. I found out that I can set a parameter in Fluent for my heatet body so that I can change the power systematicly. I can change the parameter sets in Workbench. What I still need is to set an output parameter. I want to set some points and the output parameter should be the temperature at that points. Where can I set the points and read out its temperatures? Can I do this in Post-CFD? Thanks in advance an best regards! |
[swak4Foam] outputTime in Swak function | immortality | OpenFOAM Community Contributions | 20 | October 6, 2022 12:08 |
Scheme - output temperature as an input + increment | rydol | Fluent UDF and Scheme Programming | 4 | January 9, 2020 06:47 |
How To Get A value in C In An Output Parameter Based On An Expression In CFD-Post | Shomaz ul Haq | CFX | 2 | April 25, 2016 13:17 |
Output Parameter | M4x1m | ANSYS | 1 | November 13, 2014 15:15 |
Accessing output parameter value in scheme | nnvoro | Fluent UDF and Scheme Programming | 1 | October 11, 2014 14:53 |
