source term
Old   June 15, 2020, 08:43
Default source term
Lukas
lukas' is on a distinguished road
Hello everybody!
I want to simulate the effect of a heater in an installation space. In comparison to the other components the heater is quit thin. I think I'll get in trouble with the mesh if I model the heater as a solid body. Therefore, I thought I can add the power of the heater on a surface.
For a solid body I found the possibility to add a source term (as shown here: https://youtu.be/3FyycLuQxE4?t=1183)
Is there also an option to add a source term to a created named section surface? I didn't find an option for this.
Thanks in advance.
Best regards!
lukas' is offline   Reply With Quote
Old   June 15, 2020, 08:56
Default Source Terms
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Sources are applied to cells. For boundaries, you can apply flux, which is same as source. Since field values are constant within a cell, you can also identify cells within which the heater would exist, if included, and add source terms only in those cells.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 03:50
Source Term due to evaporation in energy transport equation styleworker OpenFOAM Programming & Development 3 September 7, 2022 03:09
Source term for EVAPORATION in Energy Equ. - technical difficulty ? Kummi OpenFOAM 1 September 9, 2019 09:32
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
