June 12, 2020, 08:17 |
Boundary Condition Setting up
Mariposa Bon
Rep Power: 5 |
I recently want to simulation an axial fan that work like wind tunnel so the input pressure is negative and the output pressure is positif. I also want to input mass flow 32.5 kg/s.
But the problem is, i've trying to make the boundary inlet is mass flow but its still goes false, while the result in input and output get exchange. Honestly i still confuse how to use boundary condition, like pressure inlet, velocity inlet, massflow, exhaust fan, intake van and also function each of them. I really need your help guys, please help me. Thank you |
June 14, 2020, 11:50 |
#2 | |
mCiFlDk
Rep Power: 6 |
Could you share with us a screenshot of the whole bunch of boundary conditions? Regards. |
June 15, 2020, 07:06 |
Boundary Condition
#3 | |
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
June 15, 2020, 13:04 |
Mariposa Bon
Rep Power: 5 |
Hi mariposa,
Could you share with us a screenshot of the whole bunch of boundary conditions? blade_LI.jpg Well, firstly i just drew a boundary only in (a) and in (d) but my lecture said that i've to add some new selection name in (b) and (c), so in my BC the (a) i set to mass flow inlet that has 32 kg/s and the pressure is -4336 Pa and in the (d) i set an outflow because i want to know about the outlet pressure. 2 (2).jpg but in (C) and (d) i get confused because the BC show just like this option thats why i get confused what should i do with that boundary condition, while in my real data the (a) is -4336 Pa and in (d) is 1236 Pa. thats why i need ur help. thank you Last edited by mariposa; June 15, 2020 at 13:13. Reason: now the picture was showed |
June 15, 2020, 13:11 |
#5 | |
Mariposa Bon
Rep Power: 5 |
June 15, 2020, 13:13 |
#6 | |
Mariposa Bon
Rep Power: 5 |
Well, firstly i just drew a boundary only in (a) and in (d) but my lecture said that i've to add some new selection name in (b) and (c), so in my BC the (a) i set to mass flow inlet that has 32 kg/s and the pressure is -4336 Pa and in the (d) i set an outflow because i want to know about the outlet pressure. Attachment 78373 but in (C) and (d) i get confused because the BC show just like this option thats why i get confused what should i do with that boundary condition, while in my real data the (a) is -4336 Pa and in (d) is 1236 Pa. thats why i need ur help. thank you |
June 15, 2020, 16:18 |
Boundary Conditions
You cannot apply any condition at the interior boundaries, nor are those required. Check with your lecturer why those are required; possibly for data extraction. Or if you wish to rotate the rotor. Then, it has to be interface and you have to slit the boundary or generate non-conformal mesh at the meshing stage. So, check before you proceed.
If the flow is compressible, then you have to set operating pressure as 0 and use only positive pressure values at the boundaries. Do not use negative pressure values. Use mass flow at the outlet and pressure inlet at the inlet. Do NOT use outflow.
June 15, 2020, 20:42 |
#8 | |
Mariposa Bon
Rep Power: 5 |
boundaries condition, fluent |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 05:53 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Time dependant pressure boundary condition | yosuke1984 | OpenFOAM Verification & Validation | 3 | May 6, 2015 06:16 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 11:32 |
