June 18, 2020, 14:24 |
Fluent needs a lot of ram
Rep Power: 9 |
very scarce, saved by the bell
356.2 million cells |
June 19, 2020, 01:36 |
Tu Can
Rep Power: 9 |
Maybe you could use "(flush-cache)" after setup case and data to free RAM before calculation.
June 19, 2020, 06:54 |
Question
I don't really see a question posted, but if you are asking about whether RAM is enough or not, then it may or may not be enough. Rule of thumb is to multiple the number of cells in million by 4 to get RAM required in GB to run a single-phase, turbulent, steady-state flow. If more equations are added, RAM requirement increases accordingly. So, if whole of the RAM is available in your system, it might work.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
New System for Fluent | DL598 | Hardware | 17 | January 8, 2021 11:56 |
New workstation for different usage scenarios - CPU and RAM | natem | Hardware | 6 | August 7, 2013 02:47 |
Help with RAM choice for Fluent Simulations!!! | spk | Hardware | 8 | January 31, 2012 13:16 |
fluent 32 bit maximum RAM | Mike | FLUENT | 2 | August 19, 2006 09:45 |
Fluent - Windows XP-Prof 32bit - 4 GB RAM | Peter Specht | FLUENT | 5 | February 14, 2006 12:05 |
