"List/Show all" menu in Fluent 2020 R2
Old   August 5, 2020, 15:40
Default "List/Show all" menu in Fluent 2020 R2
Phelype Oleinik
PhelypeOleinik is on a distinguished road
Hi all,
I downloaded Fluent 2020 R2 Student from the ANSYS website and now I'm trying to run some old cases.
In previous versions (19.3, if I recall correctly), I could define materials, then assign them to different phases and name them. To list the phases I'd go to the Ribbon under "Physics -> Phases -> List/Show All".
However in 2020 R2 I can't find a "Phases" menu there, let alone the "List/Show All" button. Does anyone know where did that button go?
Thanks!
Cheers,
Phelype
PhelypeOleinik is offline   Reply With Quote
Old   August 7, 2020, 14:58
Phelype Oleinik
Okay, two days later I found it (rather, a friend found it and showed to me :)
For the record, the List Phases menu is now at “Physics -> Models -> Multiphase”, then in the window that pops up, at the top you see several tabs (opened at “Models” by default): click on “Phases” and voilà.
Hope it helps.
Phelype
fluent 2020 r2, menus, phases
Fluent 16.0.0 and Ubuntu 12.04 fivos FLUENT 11 January 8, 2018 13:39
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling spaceprop FLUENT 5 September 2, 2014 09:43
Error in reading Fluent 13 case file in fluent 12 apurv FLUENT 2 July 12, 2013 07:46
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
