How to define inlet velocity in 45 degrees from the inlet ?
Old   July 14, 2020, 11:46
Default How to define inlet velocity in 45 degrees from the inlet ?
Kaboka
kaboka is on a distinguished road
I would like to define a velocity inlet in 45-degree angle for my quenching multiphase flow (water and air) case in 2D. I have tried to give the axial and radial velocity to inbuilt system, however it does not give me the exact solution. Could anyone help me about it? Do I have to add a UDF file or is there any other tricks you could recommend?
Following pictures are my actual case and the velocity vector that I want:
https://imgur.com/bSpbkGc
https://imgur.com/ixaruoy
Thanks in advance
Bora
kaboka is offline   Reply With Quote
Old   July 16, 2020, 14:28
Guvennergiz's Avatar
Guven Nergiz
Guvennergiz is on a distinguished road
Hi Bora,
I am not sure but;
First of all, you need to divide the inlet section into two parts (from middle ofc). Then define the direction vectors and speed inputs one by one. Like in the screenshot below (in this coordinate system your velocity vectors can be X=1/Y=1/Z=0 and X=-1/Y=1/Z=0).
I hope that this can be a solution of your problem.
Best regards,
Güven
Guvennergiz is offline   Reply With Quote
Old   July 20, 2020, 06:50
Kaboka
Originally Posted by Guvennergiz View Post
Hi Bora,
I am not sure but;
Best regards,
Güven
Hi Güven,
Thanks for your answer, as my case is a 2D axisymmetric I don't have a coordinate system section in velocity window. I need an conical velocity profile which has a 45 degrees angles. I tried the following method but it doesn't give me a good solution. I'd be appreciated if you have any idea about that situation.
Bests.
Bora
Old   July 21, 2020, 01:40
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
axial^2 radial^2 component together should give you 1
also you can use other reference frame, not absolute
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   July 22, 2020, 07:13
Kaboka
Hi AlexanderZ,
Thanks for your advice but that didn't work. However, I found a way to define both axial and radial velocity with a Udf code individually. In Fluent, velocity vectors look good as you can see in the attachments, but when I load results to the CFD_Post it does not give the good conical spray nozzle shape. Do you have any idea what is the reason of this problem?
Bests,
Bora
File Type: c radial.c (301 Bytes, 18 views)
File Type: c axial.c (305 Bytes, 8 views)
Old   July 22, 2020, 07:54
Guven Nergiz
Originally Posted by kaboka View Post
Hi AlexanderZ,
Bests,
Bora
Hi Bora,
Glad to hear you solved your main problem.
Maybe you should run your case a bit longer to get fully developed region?
Best regards,
Güven
Old   August 5, 2020, 14:38
Kaboka
Hi Bora,
Best regards,
Güven
Hi Güven,
Unfortunatelly I have tried that as well but that was not the case. I am still trying to find the best solution here. If anyone have any idea about that I'd be very appreciated. In order to make it clear I add one more volume fraction picture on CFD-Post and what I want it really. Thanks in advance.
Bests,
Bora
ansys, axial, cfd, fluent, radial velocity
UDF Velocity profile at inlet aar007 Fluent UDF and Scheme Programming 1 June 28, 2020 22:43
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
3-D parabolic velocity Inlet - Steady state - UDF Turbulent Flow mohibanwar Fluent UDF and Scheme Programming 10 May 18, 2015 10:34
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 18:42
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
