August 9, 2020, 05:49 |
Fluent Mesh Check Fail
#1 | |
Rep Power: 7 |
Hey Fluent Community,
I have a certain mesh-check failure which I believe might be responsible for the erroneous results my simulations are giving. I will not get into the details of the simulation in this thread. I have prepared the mesh in ICEM CFD. The mesh is hexahedral. It has three fluid domains (blocks have been assigned to respective parts). Two Domains (greem and orange) are rotary one (gray) is a stationary domain. Mesh Quality in ICEM is around 0.25 Min Angle is around 18. [Not the best, but I read that most solvers accept these]. The Pre-Mesh was converted to an Unstructured Mesh. Before output to Fluent, the mesh has been split with 'internal walls' [to create interfaces in Fluent between rotary-stationary and rotary-rotary domains]. I am using Fluent 14.0. Can anyone suggest what is wrong here and what I can do to correct this? Mesh Check gives the following message in the TUI window: Quote:
August 9, 2020, 06:23 |
Rep Power: 7 |
Assigned the mesh interfaces in Fluent and ran the mesh check again.
No warnings. Says 'done'. |
icem cfd 13.0 |
Transfer of mesh from Meshing to Fluent destroys the mesh | balrog_f | FLUENT | 9 | July 28, 2018 10:02 |
[ICEM] Nuclear fuel assembly, Mesh Check: "missing internal faces, uncovered faces" | swparth | ANSYS Meshing & Geometry | 2 | June 27, 2017 07:12 |
hybrid mesh created by pointwise fails mesh check in fluent due to left-handed faces | Hamid.de | Pointwise & Gridgen | 4 | November 9, 2016 11:20 |
[ICEM] Error reading 2D hybrid ICEM mesh into Fluent | Kloz | ANSYS Meshing & Geometry | 1 | June 6, 2016 13:45 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
