why exported xy data will jump regarding to position in fluent?
Old   August 13, 2020, 04:40
Default why exported xy data will jump regarding to position in fluent?
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
I tried to export xy data in a two dimensional case. x is position coordinate and y is exported values. I found that exported data will suddenly jump from one position to a far away position. For example, the whole length of the two D surface is 15 mm, the exported position would jump from 3 mm to 7 mm. However, the exported positions should be node coordinates in the mesh I believe. In some other cases, this jump does not happen in which I can export continuous xy data.
The node distribution is same in these cases. I am wondering why would this jump happen?
ps: I just used the imbedded post processing tool of fluent
Best regards
weiqiang
Weiqiang Liu is offline   Reply With Quote
jump, post processing, xy plot
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
high continuity Fluent modeling ABL with WRF/CALMET data xitao21 FLUENT 1 May 2, 2019 10:20
External Magnetic Field Data Format for FLUENT MHD Module eduardvinter FLUENT 0 January 24, 2019 01:54
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
