Problem with DES Model of Airfoil in Ground Effect
Old   August 18, 2020, 04:50
Default Problem with DES Model of Airfoil in Ground Effect
Daniel
d_turner is on a distinguished road
Hi all,
I have plotted the turbulent viscosity ratio for a DES of an airfoil in ground effect and have noticed a worrying feature I cannot figure out. The figure attached shows that the regions far from the wall have a higher level of turbulence, before becoming more laminar in the region closer to the airfoil. This is confusing, as I set a very low level or turbulent intensity at the inlet (0.7%). May it be due to poor aspect ratio as the mesh changes near the airfoil? Any help is much appreciated.
d_turner is offline   Reply With Quote
airfoil, des, fluent, mesh, turbulent viscosity ratio
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 16, 2020 23:44
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 18:19
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
2D FFD Optimization RLangtry SU2 2 August 5, 2014 09:48
Problem with DES model mehul Fidelity CFD 0 April 12, 2006 08:00
