August 17, 2020, 04:54 |
Whats up with Fluent not closing
Rep Power: 6 |
My second question for the day from my learned Fluent user colleagues.....
While asking about Fluent peculiarities, why does Fluent sometimes refuse to close or exit? I imagine there is a active process that needs to be terminated - but how do you find and force close? I've tried fluent-close tui command and everything else I can think of. I'd prefer not using windows task manager to force the app closed! Thanks |
August 23, 2020, 08:23 |
Dico Nico
Rep Power: 7 |
Sometimes fluent does not close because you have something going on in the console. An example:
You typed: solve/set>, Fluent still waiting you to finish it, (set what? surface-tension?advance?etc...) so, it won't close. Check if you have unfinished comands in the console. |
CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 08:08 |
How to solve UDF compilation problems in Fluent. | pakk | Fluent UDF and Scheme Programming | 16 | September 10, 2018 02:48 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
