August 17, 2020, 15:40 |
Saving Transient solution data files
Ajiazi
Rep Power: 6 |
Hello
I am doing transient simulation for 3D bluff body using HPC cluster account. I have large number of time steps 3500. If I save data for each time step or every 10 time step, then downloading such huge solution files for a very large number of time steps from cluster account is really a problem. Is there any way to save data of all the time steps in one file? if not then can i save data of interest only for each time step.( X vorticity in my case.) |
August 23, 2020, 08:10 |
Dico Nico
Rep Power: 7 |
Yes you can! Double click in Calculation Activities, create a automatic export and then you can select the variables of interest.
August 26, 2020, 02:42 |
Moritz Kuhn
Rep Power: 17 |
If you are interested of X vorticity only on a certain surface, just crate a report file via "Report Definitions". And or alternatively use Solution Animation to create a plot every 10th time step of X vorticity automatically.
August 29, 2020, 14:58 |
Ajiazi
Rep Power: 6 |
thank you for the suggestion
I need to analyse X vorticity at different cut planes over the body. Is it possible to export data for various cut planes. |
August 29, 2020, 15:08 |
Ajiazi
Rep Power: 6 |
Dear Moritz thank you for the reply.
As I tried to monitor x vorticity but the file save have same size as of other data files so the problem remains. As I need to monitor x vorticity though various cut planes to I guess solution animation would not help. Is there any other way around. |
August 31, 2020, 02:58 |
Moritz Kuhn
Rep Power: 17 |
First define your cut planes. Then go to Report Definitons and create a Surface Report, where you can write the average, min or max of the x vorticity in this plane to a file. You can even define a single point. In this way you have one file for all time steps, with this single information. What you did results in one single file for each time step. Isn't it?
August 31, 2020, 06:51 |
#7 | |
Sai Krishna
Rep Power: 8 |
now, u can select whatever definitions u created either for reporting or plotting. here u can club all definitions into one file and those wont get averaged and all data will be saved for each iteration. hope this helps u. Regards |
September 7, 2020, 04:47 |
#8 | |
Ajiazi
Rep Power: 6 |
I have defined various cut planes and in surface monitors i select the variable to interest but its saving text data. I need to visualize the flow fields. Sorry for the late response. |
September 7, 2020, 04:49 |
#9 | |
Ajiazi
Rep Power: 6 |
I follow your steps and create surface monitors for the cutplanes its now saving text files i need to visualize the flow fields. |
Saving data transient simulation - file format | batdan | FLUENT | 0 | June 21, 2019 04:55 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli | mmkkeshavarzi | FLUENT | 0 | June 22, 2016 08:26 |
UDF for saving data of a transient simulation at particular locations | sreerajvarma | Fluent UDF and Scheme Programming | 3 | July 16, 2014 07:00 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
