Residuals increasing after few iterations
Old   September 27, 2020, 05:15
Default Residuals increasing after few iterations
Ajiazi
Aijiazi is on a distinguished road
I am simulating 3D slender body at high angle of attack. Re=3 million. y+<1. I tried different meshes from course to fine but the problem remains. I am attaching residual picture. Any help is highly appreciated. I am stuck at it for a long time.
Aijiazi is offline   Reply With Quote
Old   September 27, 2020, 22:41
rajesh
saihasil is on a distinguished road
Use coupled algorithm and make the Courant number as 0.5
saihasil is offline   Reply With Quote
Old   September 28, 2020, 00:49
Ajiazi
Thank you for your reply Saihasil,
I am using coupled scheme, i tried range of courant number from 5 to 200. But following your suggestion i will try with 0.5 and will let you know the result.
Another thing i want you to know, if I make Y+=30 then the problem goes away. with courant no =20.
but the results not good as it does not capture separation.
Old   September 28, 2020, 02:28
Ajiazi
i tried that method but still doesnot work.Residuals still increasing
Old   September 28, 2020, 07:50
rajesh
If the residual is increasing after sometime it may diverge.
So, do the Grid Independence Test
Make the three cases of element size and compare the results.
Old   September 28, 2020, 08:46
Ajiazi
i,cant complete the solution because wheb the residual increases it says,divergence detected in amg solver.
i seek some suggestion, someone say to calculate time step for this case, but i dont know how to calculate time step.
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 05:49
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
