Postprocessing results on complex surface
Like Tree1Likes
  • 1 Post By RandomStud
Old   October 1, 2020, 07:23
Default Postprocessing results on complex surface
Diego
RandomStud is on a distinguished road
I am relatively new working with ANSYS and I am trying to find a way to show results on a complex surface. I am studying wind conditions around a building and I want to to have the results in a surface such as the one for the terrain but 1.5m above. I can only have an horizontal plane.... (see below):
How can I do this with Ansys?
thank you in advance.
RandomStud is offline   Reply With Quote
Old   October 2, 2020, 04:09
Micael
Micael is on a distinguished road
This is fluent, right?
Of course this can be done. Many ways actually.
The most neat and appropriate way for you is probably to use "Transform Surface" tool in fluent (see attached picture), where you will create a new surface being a translation of the ground surface.
Another way would be creating an iso-surface based on wall distance. See attached picture. However, this surface will also circumvent the building, which you might not want. That problem can probably be fixed by temporary setting building boundary to something else than wall, just for sake of iso-surface creation and visualization. Note that if you turn it back to wall boundary and iterate, the iso-surface will update and circumvent the building again.
Yet another way, would be to actually draw it in geometry, mesh it and just set it as an interior boundary so that you can use it for post-processing. This approach work best if the need for such surface is realized at geometry step, before doing the mesh, but for you it means doing the mesh and simulation again...
Micael is offline   Reply With Quote
Old   October 2, 2020, 06:50
Diego
Hello Micael,
Thanks a lot for your reply! That works for me. I tried everything you said except for doing the mesh and simulation again.
The transform surface tool is exactly the solution I was hoping to find.
Thank you for taking the time to answer back, this is solved now
Best regards!
Micael likes this.
ansys, fluent, postprocessing, wind
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[snappyHexMesh] Problem with Sanpper, surface still Rough Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 November 5, 2014 12:05
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 10:45
Convergence but incorrect results in Free Surface flow fmjb CFX 10 October 26, 2011 07:18
