Negative cell volume detected in Fluent Dynamic mesh |
November 20, 2020, 01:19 |
Muskan Somani
Rep Power: 5 |
Dear all,
I am trying to simulate the motion of a 3d elliptical fin. I have defined a UDF to give heave and pitch motion to the fin. My mesh is Unstructured tet with a boundary layer of hex elements. While previewing the mesh motion, I receive an error of negative cell volume. I have tried reducing the time step as low as 0.00001s. I have used the following settings: 1) smoothing parameters: spring constant factor= 0.001 Convergence tolerance = 0.001 Number of iterations = 50 Elements : all Laplace node relaxation = 1 2) Remeshing parameters: Local cell and Local face other parameters selected according to Mesh scale info While defining the motion I have chosen 1) rigid body motion with UDF for fin 2) Rigid body for the boundary layer with UDF 3) The fluid around the fin is set up as deforming with smoothing and re-meshing Can anyone suggest any improvement in these settings to get rid of error? |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Error:Negative cell volume! - Setup Fluent for FSI Benchmark TUREK/HRON | nova.08 | FLUENT | 0 | August 5, 2015 06:50 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
