November 18, 2020, 17:41 |
cross flow fan simulation
navid
Rep Power: 6 |
Hi. I am simulating a two-dimensional cross-flow fan in fluent. The fan is inside the case. The boundary condition of the input and output are both output pressures. The rotational speed of the fan is known. But the current is not established from input to output. Where is the problem? Thank you for your help
November 21, 2020, 06:15 |
Manolis Theofilos
Rep Power: 5 |
November 21, 2020, 19:05 |
#3 | |
navid
Rep Power: 6 |
November 21, 2020, 19:18 |
Manolis Theofilos
Rep Power: 5 |
I assume you have set your rotating regions correctly (correct axis, correct rotation)?
Also, the Wall boundary condition that is your impeller needs to be set to "moving Wall", Rotation, Relative to adjacent cells (Which are the cells in your rotating region) and have a rotation of 0 |
November 22, 2020, 06:32 |
#5 | |
navid
Rep Power: 6 |
November 22, 2020, 06:50 |
Manolis Theofilos
Rep Power: 5 |
Assuming you are running a transient simulation, have you defined your timesteps correctly?
If you are running steady state, try running first at 10% of your RPM, then double that and continue your solution. Repeat until you reach the 100% of your RPM |
November 22, 2020, 18:03 |
navid
Rep Power: 6 |
I use transient simulation and set the timesteps according to the reference article.
November 22, 2020, 18:07 |
Manolis Theofilos
Rep Power: 5 |
Try running steady state until it converges and then use the converged steady state solution as a starting point for your transient analysis.
Also, what turbulence model do you use and have you made sure your y+ is suitable for your turbulence model? Is your mesh resolution adequate? If those fail, I am out of ideas |
November 23, 2020, 17:14 |
#9 | |
navid
Rep Power: 6 |
November 23, 2020, 17:47 |
#10 |
Manolis Theofilos
Rep Power: 5 |
If you are using k-epsilon the your y+ should be between 30 and 300.
A more thorough explanation of y+ is found here: https://www.youtube.com/watch?v=fJDY...idMechanics101 https://www.youtube.com/watch?v=nSdV...idMechanics101 You can plot your y+ value by going to results->graphics->contours. You will need to select all your walls, use turbulence as a value from the drop down menus and yplus from the drop down menu right below turbulence. If your y+ is above 300 you will need to refine your mesh on the wall (inflation layers). What version of k-epsilon are you using? If you search for a book called "Developments in turbomachinery flow. Forward curved centrifugal fans" by Montazerin, Akbari and Mahmoodi they recommend the k-e RNG model as it gives closer results to experimental. standard k-e and k-w tend to underpredict the flowrate and pressure. |
November 25, 2020, 23:20 |
#11 |
duri
Rep Power: 17 |
Is it possible to do cross flow fan simulations in 2D. I am assuming that the fan you mentioned is an axial fan. It is highly 3D problem. Are you modelling fan as geometry or source term? Could you share your flow domain.
November 27, 2020, 16:43 |
#12 | |
navid
Rep Power: 6 |
November 27, 2020, 17:10 |
#13 |
navid
Rep Power: 6 |
Yes. Imagine cutting a 3D fan with 35 blades inside a case perpendicular to the axis of the cross flow fan.
November 27, 2020, 17:19 |
#14 | |
navid
Rep Power: 6 |
Similar to the link above |
November 28, 2020, 01:34 |
#15 |
duri
Rep Power: 17 |
The fan doesn't appear effective. Not sure how the flow enters the blade against centrifugal force from top. What is the actual problem what is the full 3D geometry.
November 28, 2020, 12:00 |
#16 | |
navid
Rep Power: 6 |
The full 3D geometry involves a cross-flow fan with 14 blocks inside a case. But by zeroing the thickness, I analyze the problem in two dimensions. |
November 29, 2020, 02:52 |
#17 |
duri
Rep Power: 17 |
It is not problem at all the, flow is driven by difference in total pressure at inlet + increase in total pressure and static pressure at exit. Here the total pressure at inlet and static pressure at exit are almost same. So total pressure increase in fan. Your right parameter is fan pressure ratio and flow rate. When you fix flow rate at inlet then boundary is driving the flow and not the fan.
November 29, 2020, 11:48 |
#18 | |
navid
Rep Power: 6 |
cross flow fan, fan flow, fluent |
Jet fan and Tunnel simulation | ahlo7 | CFX | 9 | November 13, 2019 04:54 |
Axial fan compressor - Mass flow not matching | miguel_mazzu | CFX | 3 | December 3, 2017 18:33 |
Fan Simulation Mixing plane interface reversed flow | rvl565 | FLUENT | 0 | December 7, 2014 13:22 |
Flow Simulation Outlet Fan | D.Castle | FloEFD, FloWorks & FloTHERM | 0 | June 30, 2009 15:00 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
