How to switch off wall functions in ANSYS FLUENT? |
December 11, 2020, 05:07 |
harshavardhanps
Rep Power: 5 |
I am doing my simulations in ANSYS Fluent. I am trying to resolve viscous sub layer (in a closed duct with air flowing at a Mach number<0.1, flow occurs at room temperature). I prepared my mesh with y+ value~1 and i am using SST K-OMEGA turbulence model.please help me with the following questions.
1) There is no option to turn off wall function in Ansys Fluent how to switch off wall functions because i am trying to resolve viscous sub layer accurately with out wall function. My objective is to predict exact location of flow separation. 2)OR will wall functions be automatically turned off if my mesh is fine enough to produce a y+~1? 3)Do i need to solve energy equation as viscosity dissipation turns high grade mechanical energy into heat? How much error can I expect in the solutions if the energy equation is turned off? your help is much appreciated. |
December 11, 2020, 07:50 |
duri
Rep Power: 16 |
If you don't turn on any wall function it will use wall integration approach. Enhanced wall function will take care automatically based on yplus. No need to turn on energy equation.
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Can you help me with a problem in ansys static structural solver? | sourabh.porwal | Structural Mechanics | 0 | March 27, 2016 17:07 |
Ansys Fluent Turbulence Model wall function | sr71bb | ANSYS | 0 | August 13, 2015 15:57 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
