1st order slip, Fluent, Urgent
Old   November 3, 2013, 20:55
Default 1st order slip, Fluent, Urgent
Karan Bansal
Karan is on a distinguished road
Can anyone help me with how to implement first order slip condition to simulate rarefied gas flow (Kn = 0.3-0.7) in Ansys Fluent 13. If there is a tutorial available online? Could not find any.
Thanks
Karan is offline   Reply With Quote
Old   November 4, 2013, 08:59
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Fluent has a boundary condition called "low-pressure boundary slip" that corresponds to a first order slip boundary condition for rarefied flows.
It is only available for laminar simulations.
Searching in the fluent manual for the name of this boundary condition will bring up all the information you need.
Nevertheless, a Knudsen number of 0.3...0.7 is way beyond the slip flow regime so the results will be poor.
flotus1 is offline   Reply With Quote
Old   November 4, 2013, 16:08
Karan Bansal
Hello Flotus,
Thanks for your reply. The low pressure condition does not ask for any accomodation factor or any other parameter (like the velocity gradient at the all). Does Fluent define all those values by itself ?
Also from what i know, it is valid for flow over flat plates only (or maybe some airfoils with low curvature). I want simulations for a wavy wall (sinusoidal wave function). Do i need to write UDF for this ?
Thanks
Old   November 4, 2013, 17:28
flotus1's Avatar
Alex
Accomodation factors and the other settings for the boundary condition become available in the materials tab as soon as the boundary condition is activated.
You are right, the derivation of this boundary condition implies a flat wall (curvature radius >> mean free path).
If you want the "correct" boundary condition for curved walls, a UDF is the only way.
However, even the slip boundary condition for curved walls implies a Knudsen number in the slip flow regime.
Old   January 8, 2021, 07:01
zhangdongjie
zhangdongjie is on a distinguished road
Low pressure boundary slip only works in 3D. How can I open this button in 2D?
zhangdongjie is offline   Reply With Quote
1st order vs 2nd order ken FLUENT 8 March 14, 2013 03:43
Order of accuracy: 1st or 2nd order? fisch OpenFOAM Running, Solving & CFD 2 July 6, 2011 04:37
Changing LimitedLinear to blend with 2nd order upwind instead of 1st order upwind stevenvanharen OpenFOAM Programming & Development 0 April 11, 2011 05:54
High Resolution (CFX) vs 2nd Order Upwind (Fluent) gravis ANSYS 3 March 24, 2011 02:43
Urgent help needed- FLUENT to ANSYS Omer Main CFD Forum 3 September 18, 2006 10:24
