the vaporised zone should be defined as pressure ?
Like Tree1Likes
  • 1 Post By WANGHONG
Old   September 23, 2007, 21:17
Default the vaporised zone should be defined as pressure ?
WANGHONG
hi,all The very strong density of power delivered by the laser beam causes the metal to boil a few milliseconds after the beginning of irradiation. The pressure created by the intense vaporisation tends to dig the molten metal zone.That is,recoil pressure make the free surface of the molten metal zone depressed.i want to model the depressed surface and track free surface using VOF method.My question is that the vaporised zone should be defined as pressure inlet or mass inlet or velocity inlet?
anoop.k.unni likes this.
Old   February 26, 2017, 23:55
Aaronaiy
Aaronaiy is on a distinguished road
Originally Posted by WANGHONG
;145627
Hello! Did you add the recoil pressure successfully? Thank you!
Aaronaiy is offline   Reply With Quote
Old   January 18, 2021, 04:38
ANOOP K UNNI
anoop.k.unni is on a distinguished road
Hi there.. can you tell me how you added recoil pressure to the momentum equation
anoop.k.unni is offline   Reply With Quote
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Pressure limit in the recirculation zone Hìr0 OpenFOAM 1 April 5, 2011 08:56
Pressure and Temperature UDF for Cell Zone elixer2104 FLUENT 0 February 24, 2011 11:54
