Error: Surface creation failed!
Old   March 6, 2006, 05:30
Default Error: Surface creation failed!
Lutz
I want to create a point surface for plotting data and always get this error message:
Error Object: #f
I dont know whats wrong. Has anyone an idea how to solve this problem?
Old   March 6, 2006, 05:37
Default Re: Error: Surface creation failed!
Rizwan
check your domain extents in first case. if you are tryin to create a surface outside your domain Fluent wont permit to do so.
Next chek that you are using proper co ordinate representation, i mean make sure your vertices are correct in both x y and z directions.
Regards.
Old   March 6, 2006, 06:23
Lutz
thx for your answer.
the point is inside the domain extents, this cant be the problem. what do you mean with 'proper coordinate representation'? its only one special point thats causes this error, others are working without any problems. so i think its no type error or something like this.
Old   March 7, 2006, 01:30
Rizwan
i dint mean tht it was typing error when you entered the value using keyboard. I was saying that suppose you want to define a verticle line yet if you vary x1 and x2 values along with y values then also such error results.
Old   July 20, 2016, 15:12
Default Select the nearest line
Vedant
vedant is on a distinguished road
I faced the same problem. Then I tried taking the line slightly above the intended. That should not make much difference to the solution but I could find only this way to do.
I wanted line y=z=0 but that gave me error. So, I took the end points as x=0,y=0,z=1e-6 and x=0.3,y=0,z=1e-6.
vedant is offline   Reply With Quote
Old   March 24, 2021, 04:00
Default check if you have an axisymmetric problem
ahmed
andalolo is on a distinguished road
i had the same problem when trying to select a point it fails, it turned out i was selecting the point in the wrong side of the reactor (or material).
See for me i have an axisymmetric problem, meaning the problem is resolved only in one half of the volume and then it is duplicated to other half , so when i selected the point (or introduced the coordinates) in the wrong side it fails , i just had to select the same point but in the opposit side and it worked.
I hope this helps
andalolo is offline   Reply With Quote
Transient boundary conditions Jarrod Sinclair (Sinclair) OpenFOAM Running, Solving & CFD 133 May 6, 2015 06:21
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
