Deactivating a zone in the middle of simulation
Like Tree1Likes
  • 1 Post By Rashi
Old   April 9, 2021, 12:02
Default Deactivating a zone in the middle of simulation
Rashiga Walallawita
Rashi is on a distinguished road
Hi all,
I'm doing a FSI simulation for a melting and soldification process. After the mold solidifies I need to let it cool until it reach room temperature. Therefore, can I deactivate the cast zone in the middle of simulation and continue it wihtout loosing data?
Also is there a way to setup convergence criteria so that simulation stops when the mold reaches the solidus temperature?
Thank you.
Rashi is offline   Reply With Quote
Old   April 9, 2021, 14:35
Yasser Selima
Yasser is on a distinguished road
The answer to your questions, yes and yes ...
You can change the boundary condition type in the middle of simulation use Execute Commands but this could be done at certain time .. not event. If you provide more details, there might be another way that you can use ..
You can set your convergence criteria .. go to Monitor -- > Residuals -- > convergence criteria and make your own criteria. You might need to use a simple UDF to check your criteria and pass a value of the solver to stop.
Yasser is offline   Reply With Quote
Old   April 9, 2021, 14:51
Rashiga Walallawita
Hi Yasser, so we meet again!
Did you had any luck with compute canada?
I will send an reply with more detailed explanation.
Yasser likes this.
Old   April 13, 2021, 14:46
Rashiga Walallawita
Hi Yasser,
Thank you for your reply.
I'm doing a solidification/melting simulation to obtain the temperature/time output to simulate residual stresses in casted object.
In fluent simulation first I want to simulate from pouring temperature until the shakedown temperature with the mold intact and then I want to remove the mold and let it cool till it reach room temerpature.
It seems if I can have a convergence criteria I can fully automate the process right? With some custom TUI commands I mean.
Cheers,
Rashiga
fluent, fsi, melting&solidification
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 06:08
Pressure input for Velocity Inlet in middle of 2D transient Simulation Shekhaai FLUENT 1 August 30, 2016 22:43
How to setup simulation of injet Helium into Air cell zone? Shogan FLUENT 2 December 10, 2014 06:29
Sudden jumps in Courant in the middle of the simulation Pj. OpenFOAM Running, Solving & CFD 1 May 6, 2014 12:23
Porosity profile, dividing a zone, or getting zone location from zone khoopes FLUENT 0 June 2, 2012 19:39
