April 25, 2021, 00:16 |
why the absolute pressure is below zero
Shanghai
Rep Power: 5 |
I use fluent to simulate a 2D deep cavity, the model is laminar. Boundary condition: velocity inlet and outflow, I use outflow because I do not know the back pressure and I hope the flow can flow through the outlet naturally. the gas is an incompressible ideal gas because the outflow does not allow the compressible gas. the operation pressure is 101325Pa. the gauge pressure I input is 0. but why the result shows that the absolute pressure is below zero?
April 25, 2021, 00:30 |
Lucky
Rep Power: 66 |
That's a good question because the default limiter won't let the absolute pressure go below 1 Pa. Maybe you can gather your facts and present them better and then maybe someone can help.
April 19, 2022, 09:54 |
The same question
wgp
Rep Power: 4 |
I meet the same question.
Regarding determinng the absolute hydrostatic pressure for air+water flow in a closed | er_ijaz | OpenFOAM | 0 | September 18, 2018 00:11 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
forcesCoeffs - how to use relative pressure instead of absolute pressure | WhiteW | OpenFOAM Running, Solving & CFD | 2 | December 22, 2015 12:40 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
about large minus absolute pressure | richard | FLUENT | 3 | December 6, 2003 09:39 |
