April 25, 2021, 07:04 |
How to create probes by using UDF?
Moonkh
Rep Power: 5 |
Dear, all.
I am considering simple 3-D pipe turbulent flow. I need to create a lot of probes to extract Pt, Ps, Tt, Ts, etc. I think there are two ways to generate probes. (If there are other options, please, let me know) 1. Input coordinates directly through GUI; 2. Using UDF. I tried typing hundreds of points, but…….I need more smart way. Does anyone know how to import coordinate file, create probes, and make report file by using UDF? I do not know anything about UDF, so I want to know this! Thanks in advance! |
April 26, 2021, 01:28 |
Alexander
Rep Power: 34 |
you can do this using journal file
you can make points using TUI commands with these points create report definitions put report definitions inside output file
best regards ****************************** press LIKE if this message was helpful |
April 30, 2021, 08:51 |
Moonkh
Rep Power: 5 |
O! Thanks a lot!
Finally, I solved the problem! I used .Scm file. It is also effective. Thanks! |
(ask) how to create UDF for inlet velocity profile | sincity | Fluent UDF and Scheme Programming | 83 | May 16, 2022 13:04 |
How can i create a UDF file? | aykut1c | FLUENT | 2 | March 22, 2017 09:27 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to create a UDF | Sean | FLUENT | 1 | June 11, 2008 23:39 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
