computed saturation temperature <= 0 error message |
February 14, 2018, 08:18 |
Hello everyone,
i'm trying to simulate the leidenfrost effect under a water droplet using the critical heat flux boiling model. i keep having the error "computed saturation temperature <=0" when i try to initialize and i didn't manage to find how FLUENT calculate this temperature or how to solve this issue. Does anyone ever encountered this problem or know how to solve it? Thanks in advance |
May 16, 2019, 09:53 |
#2 | |
Rep Power: 7 |
July 18, 2019, 10:07 |
xiaowei zhu
Hi bbarbier07, you should input the T_sat-Pressure correlation as a piecewise-polynomial (indentify the valid range of the correlation ), rather than a pure polynomial, then the problem can be fixed. I guess it's because some cells are intialized with a small pressure value, so that the polynomial may caculate a negative T_sat at the begaining of the interation, which causes the error.
October 28, 2020, 22:44 |
#4 | |
Ching Liu
Rep Power: 8 |
May 18, 2021, 22:41 |
computed, leidenfrost, saturation, temperature |
Natural convection through fin in Ansys FLUENT | hifjur | FLUENT | 9 | March 16, 2016 11:52 |
Cfd to ansys thermal to ansys structural interface | ssixr | ANSYS | 17 | July 31, 2015 15:18 |
Evaporation heat loss modelling (water temperature below saturation)? | ahmedmmx | Fluent Multiphase | 1 | June 19, 2015 06:35 |
Initialize volume temperature field with a computed field | magnounibo | FLUENT | 2 | December 11, 2009 03:06 |
ho to input a computed temperature value in a UDF | mcb | FLUENT | 0 | March 7, 2007 06:06 |
