May 19, 2021, 11:12 |
Validation NACA 2412
Danijel
Rep Power: 4 |
Hi guys,
I'm doing a validation of the NACA 2412 profile at Re=2200000. I used a C-grid with 20 chords in the front and 50 on the back. I did a first structured mesh with 60000 and 180000 knots using an adapted bias in order to have y_plus<1. However, the results regarding Cl and Cd are so different when using K-q SST and SST transitional. 60000 nodes K-W: Cl=0.21314 and Cd=0.009669 60000 nodes SST transitional: Cl=0.23374 and Cd=0.0047277 180000 nodes K-w: Cl=0.21335 and Cd=0.0096094 180000 nodes SST transitional: Cl=0.23549 and Cd=0.0046394 The results of K-w SST are much more similar to the experimental ones. Could there be any problem regarding the mesh, geometry or the boundary condition? |
May 19, 2021, 16:03 |
Lorenzo Galieti
Rep Power: 12 |
Which are the experimental results? Also at Re= 2 millions I see no reason to consider laminar to turbulent transition
May 20, 2021, 04:08 |
Danijel
Rep Power: 4 |
Thanks, I used tecnhical report of NASA. Considering that i do not have the turbolence for low attack angles, can I use SST transitional above 12 degres where i know the turbolence is going to start?
May 23, 2021, 04:06 |
Lorenzo Galieti
Rep Power: 12 |
You seem to have some confusion between turbulence and flow separation
At Re 2million your flow is going to be always turbulent, but will not always separate |
May 27, 2021, 04:11 |
Danijel
Rep Power: 4 |
Thanks, i understand
fluent naca validation |
Low Reynolds NACA 0012 validation | 35matt215 | CFX | 9 | March 17, 2019 22:12 |
NACA 0012 low speed validation problem | 35matt215 | CFX | 3 | March 4, 2019 18:44 |
XFlow Naca 0012 Validation | Mythorpios | Main CFD Forum | 1 | June 27, 2016 13:05 |
Naca 0012 validation, Cd value is too high. | Peter88 | OpenFOAM | 4 | January 21, 2014 16:10 |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 00:52 |
