How circular microchannel roughness geometry and meshing can be done?? |
May 21, 2021, 10:10 |
SUVECKSHYA
Rep Power: 5 |
I am looking towards simulation of circular microchannel and i created the geometry and mesh in micrometeres. Now in Fluent solver, micrometers units is not there and now will i have to put scaling factors and then scale or if mesh and geometry are already in microcmeters,Fluent directly keeps the domain extents in 10^-6. So what should i do? If already in domain extents by keeping the units metre, its already in value of 10^-6, do i need to scale again or leave and continue?
It is also showing solution is converged? Is it sue to the small dimension? Please give me idea. |
May 22, 2021, 12:32 |
Lucky
Rep Power: 66 |
Run the mesh check and you can check the domain extents.
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 07:58 |
[ICEM] Problem Meshing Asymmetrical Geometry | Madhatter92 | ANSYS Meshing & Geometry | 1 | December 23, 2017 05:56 |
[ANSYS Meshing] CATIA Geometry Generation and Meshing | danielsullivan | ANSYS Meshing & Geometry | 0 | April 3, 2017 21:11 |
Geometry for Confined Circular Jet | Greatness | FLUENT | 0 | October 1, 2013 05:04 |
