Simulation no longer converges from an angle of 25 degrees
Old   May 23, 2021, 11:32
Default Simulation no longer converges from an angle of 25 degrees
rasmvs is on a distinguished road
Hello all,
For a school project, I am trying to simulate the behavior of an underwater towed hull. The hull consists of a myring-hull shape and four rudders (two for the height and two for the lateral shear). I have tried so far to keep the mesh as fine as possible. At a speed of 3 m/s I now change the attacking angle of the elevators. Up to an angle of 20 degrees the solution converges but from 25 degrees the result does not converge anymore. Is the assumption correct that the body begins to oscillate underwater and the solution can therefore no longer converge? I have made screenshots of the settings. Does anyone have any tips to optimize the simulation?
And this happens from an angle of 25 degrees:
the corresponding yaw of the body:
Best regards
rasmvs is offline   Reply With Quote
Transient Simulation in CFX ashtonJ CFX 1 September 28, 2018 01:18
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Normal vector, slope and aspect angle g_niro Main CFD Forum 0 February 2, 2011 17:24
