Problem with ignition in combustion
Old   February 13, 2018, 23:37
Default Problem with ignition in combustion
Akram
Aero_Tn is on a distinguished road
Hi all,
I am trying to do a simulation for methane/ air combustion.
is there any method to set the ignition temperature to 1900 K?
I tried with a spark but result was very bad since it was not not possible to specify the ignition temperature.
anyone can help with this?
thanks
Aero_Tn is offline   Reply With Quote
Old   February 14, 2018, 09:32
Akram
no one can help?
Old   February 14, 2018, 15:29
Refik
rewol is on a distinguished road
What do you mean "set the ignition temperature to 1900K" and "bad results"?
1. You can define a region for temperature patch then patch high temperature to that area after initialization. ( 2000K should be enough)
2. If you are using steady state, make sure your species are initialized within reason.
Good luck.
rewol is offline   Reply With Quote
Old   February 14, 2018, 22:41
Akram
thank you Refik for your reply,
I already tried this, and I am waiting,
I am using LES and will wait too long to get the results
Old   May 26, 2021, 01:38
Smile
Lee
lishengnan is on a distinguished road
have you solved this problem?
lishengnan is offline   Reply With Quote
Add ignition but combustion does not occur IColin OpenFOAM Running, Solving & CFD 3 January 19, 2014 01:43
Combustion problem alok.cd FLUENT 2 April 23, 2013 08:41
fluent problem on combustion mohitmmb FLUENT 7 March 21, 2013 08:52
Combustion problem in STAR CD... help me, please! mrkokoko STAR-CD 1 September 14, 2009 17:00
Combustion, ignition limits and dealy Nebojsa Milovanovic Main CFD Forum 2 April 18, 2000 03:58
