February 13, 2018, 23:37 |
Problem with ignition in combustion
Akram
Rep Power: 9 |
Hi all,
I am trying to do a simulation for methane/ air combustion. is there any method to set the ignition temperature to 1900 K? I tried with a spark but result was very bad since it was not not possible to specify the ignition temperature. anyone can help with this? thanks |
February 14, 2018, 09:32 |
Akram
Rep Power: 9 |
no one can help?
February 14, 2018, 15:29 |
Refik
Rep Power: 11 |
What do you mean "set the ignition temperature to 1900K" and "bad results"?
1. You can define a region for temperature patch then patch high temperature to that area after initialization. ( 2000K should be enough) 2. If you are using steady state, make sure your species are initialized within reason. Good luck. |
February 14, 2018, 22:41 |
Akram
Rep Power: 9 |
thank you Refik for your reply,
I already tried this, and I am waiting, I am using LES and will wait too long to get the results |
May 26, 2021, 01:38 |
Lee
Rep Power: 8 |
have you solved this problem?
Add ignition but combustion does not occur | IColin | OpenFOAM Running, Solving & CFD | 3 | January 19, 2014 01:43 |
Combustion problem | alok.cd | FLUENT | 2 | April 23, 2013 08:41 |
fluent problem on combustion | mohitmmb | FLUENT | 7 | March 21, 2013 08:52 |
Combustion problem in STAR CD... help me, please! | mrkokoko | STAR-CD | 1 | September 14, 2009 17:00 |
Combustion, ignition limits and dealy | Nebojsa Milovanovic | Main CFD Forum | 2 | April 18, 2000 03:58 |
