October 11, 2021, 10:13 |
Swirl specification for actuator disc
Adithya
Rep Power: 4 |
Hi
I am simulating a propeller powered aircraft and am representing the propeller as an actuator disc. I am using the fan boundary condition to implement the actuator disc. I have calculated the delta pressure across the disc from Froude's momentum theory and will specify the pressure jump across the fan surface as a constant with this value. I know the RPM of my propeller as well and want to include the tangential velocity due to it. I know that this will be done by the 'swirl' definition. Question: How do I actually define this in Fluent as a boundary condition? Will I need to create a UDF to calculate rps*radial location for the local tangential velocity or is it enough if I just enter a constant with the entire propeller radius for tangential velocity? |
October 14, 2021, 04:17 |
Adithya
Rep Power: 4 |
Based on the Fluent manual (i have attached the equation), I can also insert a polynomial expression where the coefficient of r^1 is the RPS of my fan, and all other cooefficients are zero?
So, the expression I input would be " 0 0 RPS" I guess this is a correct approach? |
Swirl ratio | amin_u50 | CONVERGE | 1 | February 26, 2018 11:58 |
Quantifying the swirl in CFX, Swirl Number/Swirl Angle | tauqirnawaz | CFX | 23 | July 24, 2016 22:28 |
Quantifying Swirl | Ianto | Main CFD Forum | 0 | April 27, 2009 10:54 |
Re: swirl specification | Christian | FLUENT | 0 | September 2, 2002 08:12 |
swirl specification | Prasad Laxman Kane | FLUENT | 0 | August 31, 2002 03:00 |
