Very High Coefficient of Pressure Values for Flow Pas a Circular 2D Cylinder |
May 28, 2021, 05:57 |
SS
Rep Power: 5 |
Hello CFD Community,
I'm relatively new to Fluent, and I'm performing a 2D analysis of a flow past a circular cylinder as a part of my project. The cylinder is 6 mm in diameter and the inlet velocity of 20 m/s, making the Reynold's number 7638. The drag coefficient value is around 1.97, which agrees with literature, while the coefficient of pressure value is ridiculously high. I've used a tri mesh, with 50 layers of inflation at a growth rate of 1.2. The first element size was calculated to be around 1e-5 for a y+ of 0.8, to capture boundary layer effects. The Cp vs length plot shows values of 500, which is much too high. I also plotted cp vs theta upto 180° (since fluent plots against length), and have attached it herewith. The nature of the graph appears okay I think, but can anyone please help me with why the cp values are so high? Thanks so much in advance |
ansys 2020, cylinder flow, external aerdynamics, flow past cylinder, fluent |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
base pressure for circular cylinder | fpz | Main CFD Forum | 7 | June 20, 2005 21:30 |
