Vertical Axis Wind Turbine Simulation
Old   June 1, 2021, 10:25
Default Vertical Axis Wind Turbine Simulation
amin
amind is on a distinguished road
Hi friends
I have little knowledge of CFD and Fluent. I have questions about simulating a vertical axis wind turbine in Fluent. Problem specifications are as below:
* 3 blades H type VAWT
* 2D simulation
* Unsteady
* wind speed= 5 m/s
* Tip Speed Ratio= 1, 1.5 , 2 , 2.5 , 3
* time step size= 0.0001 s
* K-omega SST model
How can I calculate and check "Y+" in Fluent?
How many "time step" is required to the problem converges?
How many "iteration per time step" is required?
How can I calculate the "average torque coefficient"?
I know that the torque coefficient= torque/(0.5*rho*v^2*A*L) but I don't know how I can calculate and save it in the Fluent software.
Thanks
amind is offline   Reply With Quote
time step, torque coefficient, vawt
How to average the torque coefficient for vertical axis wind turbine? NotOverUnderated FLUENT 2 September 6, 2022 14:55
Modeling a vertical axis wind turbine / Negative momentum coefficient Felipe06 FLUENT 0 January 24, 2019 17:19
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) tony00 FLUENT 11 July 23, 2018 06:13
Vertical Wind Turbine rotor simulation victorb CFX 6 May 29, 2016 07:31
Vertical Axis Turbine Simulation dalecooper FLUENT 3 July 24, 2013 08:53
