June 1, 2021, 08:43 |
Transient simulation with stationary inlet
Rep Power: 5 |
Hi all,
I am trying to run a transient simulation in Ansys Fluent. I have a narrowed pipe where I prescribe a certain flow at the inlet and zero pressure at the outlet. The walls are rigid and a no slip condition was applied. I was having some convergence issues when using the steady solver, so I want to switch to transient to see if these problem resolve. I want to prescribe the same flow for all time steps. I have written a UDF that prescribes a paraboloid velocity profile at the inlet. I will initialize the velocity and pressure with 0. I am trying to build up slowly the flow at the inlet instead of forcing it all at once in one time step. Could someone help me with how I can best prescribe the flow at the inlet? I am mostly struggling with deciding how fast I will have to ramp the velocity at the inlet. I understand how I can manage it using the UDF, but on what time scale can I best increase the flow from 0 to 5.9 mL/s? I have a mesh of about 400,000 elements (mesh size 0.15mm) and in steady simulations I have seen max. velocity of 4.5 m/s. According to the courant number I would need a time step of 1e-5. Thanks in advance! Last edited by Ames; June 1, 2021 at 10:54. |
June 1, 2021, 21:22 |
Alexander
Rep Power: 34 |
from my point of view, criteria is convergence,
in best case if you can get converged simulation with 5.9 mL/s -> you don't need to decrease speed for instance start with 0.59, check residuals, increase velocity and so on
best regards ****************************** press LIKE if this message was helpful |
How to set unsteady turbulent inlet velocity using the result of another simulation? | John-Lee | FLUENT | 2 | December 27, 2016 17:36 |
Exporting data of transient simulation DURING a simulation, at user locations ? | Milan2013 | CFX | 0 | April 18, 2014 03:47 |
Transient simulation of intake manifold | Santoshnalanagula | FLUENT | 0 | January 1, 2014 07:32 |
define BCs at inlet and outlet for natural ventilation simulation | jjz2013 | Main CFD Forum | 0 | January 29, 2013 15:50 |
Synthetic (pulsatile) jet transient simulation | aero | CFX | 0 | November 6, 2009 01:10 |
