June 10, 2021, 16:56 |
Near-Wall Turbulence UDF Rocket Engine
Irene
Hello! I'm new to Ansys and I'm currently simulating a solid propellant rocket engine, in 2D and Axisymmetric. I'm doing a first, very basic simulation, using air as my fluid, and aluminum as the solid's material.
My issue is that I want to try this: when establishing the boundary conditions, I want to apply a velocity inlet boundary condition at the walls where the propellant is being consumed (I'm doing so using a UDF to implement Vielle's Law, which will calculate the velocity in the face, reading the density and pressure). But I wonder if there's a way to force Ansys to treat that as a wall, even though I'm putting the velocity inlet. I want to do this to recollect information regarding near-wall turbulence and how ansys deals with it through its different turbulence models. Can this be done with a UDF? I've been looking into it and I'm pretty lost... Any recommendations will be very much appreciated. Thank you! |
Surface Heat Transfer Coefficient driven by a UDF, using coupled wall | ryanbezz11 | CFD Freelancers | 1 | March 16, 2018 03:01 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Near Wall Turbulence in CFX | pawan1989 | CFX | 21 | December 16, 2013 05:51 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
