June 23, 2021, 02:36 |
Motion under multi-moving reference frames
Rep Power: 4 |
Hi everyone,
From the Fluent UDF manual, we know that through using the macro DEFINE_ZONE_MOTION, we can define a moving body that can rotate about a moving point, but it is still not convenient to simulate a moving body that is under multi-superposed motion since we need to update the rotation axises every timestep. So can we define multi-reference frames in this macro or another one? For example, there are a globe frame and a moving frame (frame1) that is superposed by the globe frame, and a second moving frame (frame2) that is superposed by frame1. And finally, we define a reference motion relative to frame2. How can we realize that? Any advice is appreciated. Thank you very much! The following is an example of the problem I want to model: Suppose there is a panel rotate about the z1 axis of a reference frame (frame x1y1z1), meanwhile, the frame x1y1z1 also has translation and rotation relative to the XYZ global frame as shown in the following figure. David |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
OF211: ThirdParty and /src compiled, but not /applications... | vkrastev | OpenFOAM Installation | 8 | October 18, 2012 15:53 |
Installing OpenFOAM-1.5-dev on a cluster | ZKM | OpenFOAM Installation | 4 | December 25, 2010 15:59 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
Moving Reference Frames. | J Foster | Main CFD Forum | 5 | August 21, 2001 01:13 |
