journal file:write-case-data
Old   July 18, 2012, 06:11
Default journal file:write-case-data
Lilly is on a distinguished road
Dear all,
I want to start a transient Fluent-simulation as a batch job and therefore wrote a journal file.
/file/read-case-data/ D:\TestFile.cas
/solve/set/time-step 0.01
/q
/solve/dual-time-iterate 50 200
/q
/file/write-case-data/ D:\TestFileComplete.cas
But for any reason I cannot make fluent save the final case and data files as denoted in the last lines of my journal file. I don't get any error message, but fluent just stops after the calculation. I already tried a lot of variations of the last lines.
Does anybody have an idea?
Thanks a million for all ideas and help!
Lilly
Lilly is offline   Reply With Quote
Old   July 18, 2012, 06:46
Marion
Marion is on a distinguished road
It won't help you a lot but I just tried your last command line in Fluent and it worked fine for me.
Are you sure you have the writing rights on your D:\ directory?
Marion.
Marion is offline   Reply With Quote
Old   July 18, 2012, 10:14
Andrew Coughtrie
Andrew.Coughtrie is on a distinguished road
don't bother telling fluent where to put the file, it will put it in the working directory if you just give it a file name, also needs quotes, this should work (see below), if not then try making your working directory something other than the root of D:\ say D:\Test\ root permissions can sometimes cause problems.
/file/write-case-data "solution.cas.gz"
Andy
Andrew.Coughtrie is offline   Reply With Quote
Old   September 9, 2012, 02:51
manuel
manuels is on a distinguished road
I also write a journal file. It can read the case- and the dat-data but when it wants to initialize the calculation it stops. Can someone help me?
; Read case file
rc propellerviskosimeterFluent.cas
rd propellerviskosimeterFluent.dat
; Initialize the solution
;/solve/initialize/initialize-flow
; Calculate 50 iterations
it 50
; Write data file
wd example50.dat
; Calculate another 50 iterations
it 50
; Write another data file
wd example100.dat
; Exit FLUENT
exit
yes
Greetings
manuels is offline   Reply With Quote
Old   September 10, 2012, 02:14
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hi manuels,
in the journal you posted here I see the semicolon before the command:
maybe you have forgotten to cancel it
Bionico
Bionico is offline   Reply With Quote
Old   June 28, 2021, 16:17
Adithya
Adithya_11 is on a distinguished road
Hello
I am also having this same problem. Basically, I have one script in which I just change the name of the case and data files. It works well for 2 other simulations but on one sim it doesn't write the data file. The solution converges and closes. JUst does not write
Adithya_11 is offline   Reply With Quote
Reconstruction of the parallel case with dynamic mesh makaveli_lcf OpenFOAM Post-Processing 7 October 18, 2023 11:28
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 15 October 15, 2021 06:35
Exporting fluent case data to Ensight/paraview aerogt3 FLUENT 8 May 7, 2012 09:15
save PARTICLE information in CASE and DATA Alex FLUENT 1 September 1, 2010 10:01
Error in Saving either or both case and data files Fascal FLUENT 4 July 18, 2010 11:12
