Applying a perturbation within a mesh
Old   July 5, 2021, 18:36
Default Applying a perturbation within a mesh
FinlayEeles is on a distinguished road
I'm using ANSYS fluent and I've created an external fluid flow mesh around a bluff body. I'm trying to apply a perturbation along the middle of the mesh for a period of time within my simulation by creating a bounded plane within my mesh to use as a velocity inlet. I've managed to create the surface i need in fluent setup but i can't figure out how to make it a named selection in order for it to show up in the boundary conditions tab. I cannot figure out how to create a bounded plane in meshing or design modeller in order to name it there.Is this possible or even the correct approach or do i need to create a surface or some other method, if so advice on how to do it would be appreciated as im a new user.
thank you in advance.
FinlayEeles is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] High quality mesh for wind in complex urban environment ziboaa OpenFOAM Meshing & Mesh Conversion 1 January 12, 2021 15:33
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) shubham jain ANSYS Meshing & Geometry 1 April 10, 2017 05:03
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
