July 21, 2021, 09:27 |
Hypersonic Re-entry Simulation
Alessandro Scala
Good Afternoon to all,
I'm writing in this forum, because I need help for my project about a CFD simulation in Hypersonic Conditions (Mach Numbers up to 22). I would ask to you what is the best setup in Fluent to obtain a good convergence, because all I tried was useless and I controllled my mesh and It's pretty well done, but I on't know what's the best Setup. Thank you in advice to all of you for your answers. |
July 21, 2021, 23:52 |
Alexander
Rep Power: 34 |
start with small Mach numbers, get convergence and increase Mach number for next iteration
best regards ****************************** press LIKE if this message was helpful |
July 22, 2021, 16:19 |
Alessandro Scala
Okay, This is what I think about, but even starting from small Mach numbers I do not have convergence.. I suppose I'm making mistake in setup because It's my first Hypersonic simulation in Fluent, so that I would know what is the best setup I can use in this case (Mach Number = 19)
cfd hypersonic fluent |
[ANSYS Meshing] How to make the good meshing for free surface using in water entry simulation? | ddungntu | ANSYS Meshing & Geometry | 0 | February 25, 2019 02:34 |
Hypersonic simulation in version 3 | gengen | SU2 | 8 | February 5, 2017 07:08 |
Simulation of hypersonic flow: NaN in the residual | smanist | SU2 | 2 | January 26, 2015 21:03 |
Is there any software for hypersonic flow simulation? | atmcfd | Main CFD Forum | 3 | November 28, 2010 23:28 |
hypersonic flow simulation | tamjid | Main CFD Forum | 1 | September 1, 2008 23:46 |
