February 15, 2021, 12:31 |
unsteady rotation
Alessandro
Rep Power: 7 |
Hello everybody.
I am trying to replicate in ANSYS Fluent the study of this paper: https://www.hindawi.com/journals/mpe/2017/4217217/ It concerns the evaluation of the static and dynamic derivatives of the UCAV SACCON aircraft. However I have few questions , which I hope you can answer. I am planning to use the dynamic mesh to compute everything, implementing an UDF with the DEFINE_CG_MOTION macro, where the inputs are the cg translational velocity component and angular velocity components. Regarding the evaluation of the CM_alpha, I have to impose an additional angle of attack which should be transformed ".. to additional velocity perpendicular to free-stream velocity..". What does this mean? How can I increase the angle of attack unsteadily? where should I input this increase in velocity? To me it makes no sense to impose a translational cg motion because otherwise the whole body will move vertically. AM i wrong? It looks that the change in angle of attack is done by this change in velocity. Should I just change the velocity components in the boundary conditions of the inlet? It looks simple, but I am really lost. The same applies to the CM_alpha_dot, in which the angle of attack and, hence, the velocity has a linear variation in time with a constant rate. Regarding the CMq, instead is easier because I simply use the dynamic mesh with the CG_MOTION macro and input an angular velocity of constant value. I am sorry for this long message, but I really want to explain the problem for all of you to understand my particular issues. If you need additional infos, please let me know. Regards, |
July 24, 2021, 00:50 |
sarathy
Hi Alessandro,
Have you found the procedure to solve this problem in Fluent? Even I am also interested to simulate in Fluent to estimate the dynamic stability derivatives. Thanks, Sarathy |
angle of attack, dynamic, rotating, unsteady |
Java Macro -- Passive Pith in Superposing Rotation Motion | Weidong Dai | STAR-CCM+ | 2 | August 4, 2018 05:39 |
Remeshing for Rotation in CFX via ICEMCFD | gera | CFX | 3 | September 23, 2017 12:29 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
Rotation and Unsteady Simulation | daxterss | Fidelity CFD | 2 | March 16, 2013 03:26 |
Error with the unsteady flamelet Model | Christoph_84 | FLUENT | 0 | February 25, 2010 11:06 |
