Removing Real Gas Model
Old   August 17, 2021, 11:42
Default Removing Real Gas Model
zwong8 is on a distinguished road
Hello!
I've been running simulations lately using a real gas lately as the working fluid. I add the real gas from the TUI using:
>> define/user-defined/real-gas-models/nist-real-gas-model
I've made a few observations through my usage:
  • When I add, say "air.fld" as a material, it automatically becomes the working fluid in every fluid zone.
  • Sometimes, I run into convergence issues and I change the zone material to a "simpler" working fluid (e.g. const. properties). However, even after deleting the real gas model and saving the project, if I exit out of fluent and open it back up, the default zone material is still a nist real gas.
I was hoping to get help with two questions:
  1. Is it possible to add a nist real gas model without it being auto-applied to every fluid zone?
  2. After adding a nist real gas model, is it possible to remove it as a material without having to completely reset the Fluent setup module?
Thank you very much for your help!
zwong8 is offline   Reply With Quote
Real Gas Model Mixture in Fluent Olmo95 FLUENT 0 August 14, 2020 13:04
make a new data from external .txt data and save it in a UDM etedalgara Fluent UDF and Scheme Programming 27 February 26, 2020 03:15
Can udf plays the role of excel fan-violaine Fluent UDF and Scheme Programming 2 February 18, 2019 11:01
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
UDF for thermal conductivity relation of nano fluid ngonbadipoor@yahoo.com Fluent UDF and Scheme Programming 29 April 1, 2017 03:02
