Shipeng Xu
Rep Power: 0 ![]() |
Can any researcher provide the udf for calculating the particle concentration in FLUENT DPM model using "PSI-C" method?
I tried to write this udf, but after using both "DEFINE_DPM_SCALAR_UPDATE( ParticleCon,c,t,initialize,tp)" and "C_UDMI(c,t,0)+=P_FLOW_RATE(tp)*dt/C_VOLUME(c,t)" at the same time, the residence time of particles within a cell is always cumulative over all iteration time steps and is not only the final value. Besides, the concentration is always cumulative over the flow time steps.Any suggestion or comment is welcome! |
concentration, dpm, particle, psi-c, unsteady tracking |
Display Modes | |
Running Fluent from Python: UDF Compilation problems | Ames | Fluent UDF and Scheme Programming | 5 | November 16, 2020 06:12 |
Fluent DPM UDF - Particle wall distance | Achini | Main CFD Forum | 0 | October 19, 2020 00:08 |
Erron: FLUENT received fatal signal (ACCESS_VIOLATION) in DPM Heat and Mass Transfer | Melvin | FLUENT | 2 | November 17, 2016 01:06 |
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT | subhankar_bhandari | Fluent UDF and Scheme Programming | 0 | August 19, 2010 03:09 |
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT | subhankar_bhandari | FLUENT | 0 | August 19, 2010 03:01 |
