August 28, 2021, 22:22 |
How to display pathline of only one phase??
Rep Power: 4 |
Hello, I am working on a multiphase, porous zone problem.
Water will be entering a vacant space, pushing out air. The air will be sucked into a porous PDMS zone because there is negative pressure on the bottom of the PDMS. When I display the pathline at the mid cross-section of the 3D model, it looks like the picture attached below. I would like to display water and air pathlines separately. How do I view the pathline only for water? Thank you. |
FVUS (Finite Volume Utilities and Solvers) / Wildkatze (solver) Updates | arjun | Main CFD Forum | 30 | July 22, 2017 03:27 |
Sharing links for two phase solver packages developed by openfoam community | swap_9068 | OpenFOAM Programming & Development | 1 | April 2, 2017 05:43 |
Gravity/Buoyancy/Buoyancy reference density in two phase flow | sharifi | CFX | 10 | June 9, 2014 10:23 |
Display of Phase Graphic | kailingkk | FLUENT | 0 | October 25, 2013 04:17 |
how to display values of each phase in tecplot? | major | FLUENT | 4 | October 30, 2004 04:01 |
