August 29, 2021, 10:29 |
Yplus NACA0012 15 degrees
Max
Hi everyone,
I have a small question concerning the values of the distribution of Y+ along a NACA0012 airfoil for AOA=15°. What is the reason for the difference in values between the upper and lower surface? You can see the distribution in the attached file. I specify that the distance to the wall is the same. Thank you very much ! |
August 29, 2021, 15:00 |
Lorenzo Galieti
Rep Power: 12 |
The flow is faster on the suction side of the airfoil, so you get higher y+
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
[snappyHexMesh] SHM Layer Addition Phase | dickcruz | OpenFOAM Meshing & Mesh Conversion | 4 | November 1, 2018 07:05 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
