Refer to DPM erosion rate in UDF
Old   September 11, 2021, 07:58
Default Refer to DPM erosion rate in UDF
bagh fay
baghfay is on a distinguished road
Hi
Fluent got some embedded erosion models like Mclaury , Finnie and Oka
i am wondering what is the variable name associated with those models if want to refer to them within UDF
Regards
baghfay is offline   Reply With Quote
Old   September 13, 2021, 07:14
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
not sure about this particular models
if you wanna make your own erosion mechanism use
DEFINE_DPM_EROSION (name, p, t, f, normal, alpha, Vmag, mdot)
macro
for more information read ansys fluent customization manual
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   September 13, 2021, 07:22
bagh fay
thanks for the reply
i do not want to make my erosion model
basically i just want to use the one built in Fluent
i need a way to refer to them inside UDF
but could not find a help in the customization manual
Regards
Old   September 13, 2021, 07:28
Alexander
I don't know the way to do it through UDF
switching between models can be done using fluent GUI
you can use TUI commands to control GUI
and you can use journal file with scheme+TUI to code this switching
best regards
No-error UDF for wall heat generation rate but no heat is exchanged?!? NPs Fluent UDF and Scheme Programming 0 May 11, 2017 06:19
UDF code help solve reaction rate equation palm oil zirkov Fluent UDF and Scheme Programming 0 February 13, 2017 10:34
write code UDF Fluent solve kinetic reaction rate equation palm oil zirkov FLUENT 0 February 13, 2017 10:16
volume flow rate for outlet boundry condition and dfine udf for it raminostadi FLUENT 0 December 24, 2016 01:52
DPM - Erosion model pipin FLUENT 2 November 18, 2013 05:02
