September 21, 2021, 08:15 |
Mesh Check Failed Problem
Rep Power: 5 |
I am simulating a two-axisymmetric supersonic jet impinging on a flat plate. When I am rotating my mesh in fluent, mesh check is being failed every time.
I did perform a check command, still the same. (pdf attached) Please, need help on this issue. |
September 21, 2021, 10:03 |
Lorenzo Galieti
Rep Power: 12 |
I think for axisymmetric your domain should be all with Y >0, but I see a -25 somewhere in the pic
September 22, 2021, 07:23 |
Mesh Check Failed
Rep Power: 5 |
Thank you, problem solved.
I made Ymin=0, now mesh checking is being fine. |
cfd, fluent, mesh, mesh check |
[Other] Super simple mesh, Failed mesh check | Ursmooth | OpenFOAM Meshing & Mesh Conversion | 2 | October 16, 2017 04:58 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
mesh check failed | flabbergasted | FLUENT | 3 | January 24, 2013 01:22 |
Degenerated Contact point - Mesh check failed | s.mishra | FLUENT | 0 | March 13, 2010 05:33 |
MESH CHECK FAILED right/left handed faces | Rodrigo Madariaga | FLUENT | 2 | June 28, 2001 10:15 |
